SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
SW_
Oct 15, 2019Prodigy
Mike_D_il wrote:For months I couldn't find a solution to my Raspberry Pi (Model 4) disconnecting reguarly from the AC3000. (To be more accurate - it was staying connected to the Orbi wifi, but somehow, had no access to the Internet). The Orbi was purchased in Canada, but the Raspberry Pi came from Europe. I repeatedly tried adjusting the Localisation settings on the Pi - but to no avail.
Then I came across this post. Although it specifies the RBK53, I decided to try it on my RBK50.
It's now 48 hours since I changed my Orbi to Europe and I'm delighted to see that I'm still attached to the Internet. Many thanks.
Glad to hear that this trick works out for you. Thanks for your feedback!
Mike_D_il
Nov 16, 2019Guide
On my setup, it seems to revert back to "US only" now and again. (I DO click Apply). I can't find anywhere that the Orbi automatically updates. What am I missing?
Thanks,
Mike
- SW_Nov 16, 2019Prodigy
Mike_D_il wrote:On my setup, it seems to revert back to "US only" now and again. (I DO click Apply). I can't find anywhere that the Orbi automatically updates. What am I missing? ...
Is there any events in the system log, firmware reset, etc.,? Try to reboot the Orbi after hitting the "APPLY" button to verify if the region change has persisted across reboots. You can also use cmd line via telnet window to check the region before and after reboot.
- Mike_D_ilDec 01, 2019Guide
Thanks for your feedback. I eventually found this:
https://stdin.coffee/blog/how-to-disable-auto-update-on-netgear-orbi
Mike
