Lexkok59's avatar
Apr 04, 2020
Orbi RBK53 router replaces my old router?
I just bought my new Orbi RBK53 system. Do i understand it correctly that the routerfunction is enough to protect me like a regular modem/router? Now i plugged the orbi router directly to my internet access and disabled my old router. Evertything just works fine, i was just curious for my security kind gegards Lex
  • The RBR functions just a like a router. Not a modem as it doesn't have a built in modem.
    Yes all Orbi routers include a firewall for protection.
  • FURRYe38's avatar
  • Just for my good night sleep, if i read the manual they say i must connect my orbi router to my existing router, see picture.
    But i do not have a router anymore and i juist directly plugged my glass internet cable in de internet connection on the orbi. Dus the orbi than have more than enough security?
    • FURRYe38's avatar
      The RBR functions just a like a router. Not a modem as it doesn't have a built in modem. You would plug in the RBR into your ISP modem.
      • Lexkok59's avatar
        Lexkok59
        Guide
        So the picture only is for if you have a modem, which i dont have
