Bananapine22
Dec 22, 2018Aspirant
Orbi RBK53 Router
Hello, Going to purchase this Orbi RBK53 System after the new year does this router work with the TPlink AC1200 Wireless dual band 4g lte Archer MR400 Router.
Another question any problems with the...
DickDuke
Dec 24, 2018Apprentice
It should work fine. But you will likely want to put the Modem into bridge mode. If that’s not possible, than you’ll want to put the Orbi router into Access Point mode.
The important thing is to have only one device acting as the router and serving out IP addresses via DHCP
