Bochco's avatar
Bochco
Orbi RBK53 Satellite's Firmware won't update
I just installed my Orbi (2 satellite) system and everything is working perfectly. I went to update the firmware and it wouldn't autoupdate. I then looked on the discussion boards and found I could d...
  • st_shaw's avatar
    Jan 30, 2017
    I also updated my router first.  I was able to update my satellite by navigating to the Web GUI on the satellite's IP and updating from there.  Did you try that?  You will need to determine the IP address of your satellites first.  They are listed under attached devices on the router GUI.
