fljoemon's avatar
Jul 01, 2019
Orbi RBK53 setup question - Modem/Router/Switch connection?
Greetings folks,
Planning to move into our new house. 2 storied, approx 5300 sq ft.. Spectrum cable coming in to my Office on the 2nd level. I have pre-wired Cat6 to almost all places where there is going to be a TV. Need some decent coverage upstairs & downstairs, hence opting to buy Orbi RBK53 from Costco. So Cable modem is a combo router/phone modem and I plan to disable the WiFi on it and use the Orbi in AP mode. Question is do I connect Cable Modem -> 16 port unmanaged switch -> Orbi Main AP or should I connect Cable Modem -> Orbi Main AP -> 16 port unmamaged switch. I also plan on setting up the satellites wireless as they will be residing in the halls upstairs & one satellite in the family room downstairs. Thanks for your insights!
  • FURRYe38's avatar
    Directly connection with the Orbi in AP mode to the ISP Modem would be preferred, however if in AP mode, it's not as important and you can connect the RBR in AP Mode to the un-managed switch.
    Be sure this un-managed switch doesn't have any Green Ethernet features.
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    • fljoemon's avatar
      fljoemon
      Guide
      Appreciate the reply .. I read up on it also that directly connecting the cable modem to Orbi and then the switch is preferred. The switch is a very basic HP Office 1405-16 Desktop Switch. Might have to check in on the "green" stuff as it states on the description "All models are fanless for quiet and "green" operation, and are designed for high reliability, long life, low power consumption, and low total cost of ownership. " Argh .. will need to pick up a NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch, Desktop (GS316)
      • fljoemon's avatar
        fljoemon
        Guide
        Seems like the GS316 is a green switch. Any recommendations for a 16-port non-green Gigabit switch?
