PCSP
Jul 09, 2021Guide
Orbi RBK53 Speed Issue with wired backhaul
Last time I found issue with unstable wireless backhaul. Now I using wirebackhaul. I found the problem. Orbi didn't support gigabit in WAN port or something. I use brigde mode from ISP and use P...
- Jul 15, 2021
Something to see if that works. Also might see if keeping PPPoE on ISP router, configure RBR for router mode and put the IP address the RBR get from the ISP router in to the ISP routers DMZ and speed test then...
Jul 10, 2021Guru - Experienced User
Maybe the PPPoE protocol, see some of these don't speed test well on this protocol.
Orbi does support near 900Mpbs on the WAN side:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/1827295/highlight/true#M76372
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815
- PCSPJul 14, 2021Guide
MFR: ZTE
Model: F668
Hardware Version: 5.2
Software Version: 5.2.10P3T51
Boot Loader Version: 5.2.10
I try connect follow the diagram (see attachment)
- FURRYe38Jul 15, 2021Guru - Experienced User
What happens if you leave PPPoE on the modem and set the RBR to AP mode?
- PCSPJul 15, 2021Guide
I didn't test it ... and I need ISP to set PPPoE on Router/ONU. ISP block the menu and they will reset to default setting too
If AP mode can work at 900Mbps, How I can fix it if I want PPPoE at Orbi not ONU/ISP Router?
