PCSP
Jul 09, 2021Guide
Orbi RBK53 Speed Issue with wired backhaul
Last time I found issue with unstable wireless backhaul. Now I using wirebackhaul. I found the problem. Orbi didn't support gigabit in WAN port or something. I use brigde mode from ISP and use P...
- Jul 15, 2021
Something to see if that works. Also might see if keeping PPPoE on ISP router, configure RBR for router mode and put the IP address the RBR get from the ISP router in to the ISP routers DMZ and speed test then...
PCSP
Jul 15, 2021Guide
I didn't test it ... and I need ISP to set PPPoE on Router/ONU. ISP block the menu and they will reset to default setting too
If AP mode can work at 900Mbps, How I can fix it if I want PPPoE at Orbi not ONU/ISP Router?
Jul 15, 2021Guru - Experienced User
- PCSPJul 15, 2021Guide
Ok I will try this way ...
- PCSPJul 21, 2021Guide
Now It works,
- PPPoE on ONU / ISP Router
- Orbi use Router Mode
- Test Speed with Wired - 870-920 Mbps (Up and down)
- Test Speed with Wireless - 4-500 Mbps (Up and down)
But Why I cannot use PPPoE on Orbi to get full speed?
- FURRYe38Jul 21, 2021Guru - Experienced User
Possible problem in PPPoE handling at the RBR or with the RBR and ISP Modem in bridge mode. Hard to say for sure.
At least its working now for you.
