mjbauer
May 27, 2018Aspirant
Orbi RBK53 sporadic connectivity wifi and wired
Orbi RBK50 and two Sats
I have both wired and wireless connections which seem to be sporadic?
My Vonage TA constantly goes on and off line and my printers (Brother- wifi and Epson -...
May 27, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem?
What channels are you using? Auto? Try setting 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try disabling the following and see: Disable MIMO, Daisy Chaing and Fast Roaming and IPv6 on the router to test.
Beamforming, MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router.
