Pseudocharro
Jun 12, 2020Tutor
Orbi RBK53 subnet
Hi everyone!! Here’s a totally newbie trying to set up my new Orbi RBK 53. My house is totally wired with cat6 cable and I have ethernet access in every room provided via my ISP router connected to ...
CrimpOn
Jun 12, 2020Guru - Experienced User
Short answer: "yes". If the Orbi is in the default "router" mode, then it will create a new subnet that will be frustrating to access. Put the Orbi in "Access Point" (AP) mode (on the Orbi web interface, Advanced Tab, Advanced Setup) and the primary router will assign IP addresses to every device in the network, so the NAS will not be "hidden".
Can you clarify where the "switch" is in relation to the primary router, the Orbi, Orbi satellites, and the NAS?
Pseudocharro
Jun 13, 2020Tutor
Thank you very much for your help, CrimpOn!!
I have a telecommunications box at the entrance to the house where the fiber signal arrives, equipped with a switch that distributes the signal to the different rooms; Thus (and everything inside the box) the fiber enters and connects to the modem router (HGU of O2), which in turn is connected to the switch to give signal to all the rooms in the house. The Orbi router connects by cable in the living room of the house and the Orbi satellite is one floor higher, connected by wifi to Orbi router.I have done this setup because the HGU router wifi, being tucked into the box, is practically non-existent.
Precisely to one of the LAN ports of the Orbi router in the living room is where I want to connect the NAS to be able to access it from different PCs in other rooms and use it for backup, ... and I was worried that it would be hidden in a subnet of the Orbi router but so that you comment I see that the solution is to configure the Orbi as an access point.
By the way, I was thinking that to take advantage of the NAS (DDNS service, VPN, ...) I could put the HGU in bridge mode and connect a good router with triple VLAN (that is, in the box: HGU-neutral router- switch). As it is not going to give me WIFI service, I do not need it to be very powerful in this aspect, rather that it manages the issue of network traffic, ports, well ... Any suggestion ???
Thank you again!
Thank you again!
- Mikey94025Jun 13, 2020Hero
Pseudocharro wrote:
By the way, I was thinking that to take advantage of the NAS (DDNS service, VPN, ...) I could put the HGU in bridge mode and connect a good router with triple VLAN (that is, in the box: HGU-neutral router- switch). As it is not going to give me WIFI service, I do not need it to be very powerful in this aspect, rather that it manages the issue of network traffic, ports, well ...Presumably the Orbi is a good router that can serve your needs as described. You could abandon using your current switch and instead use the Orbi router. Connect your current switch (or all its devices) into the LAN ports of the Orbi. Then you're using the Orbi as your router and have access to all its functions.
Ideally, also change your current HGU router to bridge to the Orbi router so you don't have Double NAT. You can also disable all the HGU wireless since you'd now be using your Orbi for wireless.
- PseudocharroJun 13, 2020TutorHi! Thanks for your reply!
So...HGU in bridge mode...Orbi router...switch, correct? Both satellites should be then wired-connected and used as access points, because wifi communication between Orbi router and them should be impossible as the router is inside the connection box.Moreover, if I need the three RBK53 units for wifi coverage, should I purchase another Orbi unit? I am in doubt between these two options:
1. Use the Orbi router as the main router connected to the HGU (then I have to buy another satellite), or
2.Keep the three Orbi units for Wifi mesh and connect any other router to HGU (ideally a Netgear router to ensure full compatibility)
What do you think about??
Many thanks!! - schumakuJun 13, 2020Guru - Experienced User
The O2 HGU is a tripple play device, multiple VLANs on the WAN side - you can't replace it by an Orbi router.
Keep the O2 HGU and the switch (assuming it's an all Gigabit Ethernet one) for providing LAN to the different rooms, consider to use the Orbi system in AP mode as a switch/WLAN device. No idea if the Orbi with it's switch mode is able to deal with your ISP IPTV box - there might be switches with IGMP Multicast Snooping required.
Depending on the switch installed along with the HGU, you might try to connect the Orbi satellite to an Ethernet port upstairs in another room and take the advantage of the wired backhaul.
With an existing installation as in your house, all what would be required were some wireless access points...- PseudocharroJun 13, 2020TutorThanks schumaku!
I do understand...I agree with you. With a fully-wired house, my main concern is to achieve a stable, fast wifi.
My only interest in using another router connected to HGU is the possibility of using VPN, DDNS and gain further control over my router, not usually possible with ISP Default routers
