Pseudocharro
Jun 12, 2020Tutor
Orbi RBK53 subnet
Hi everyone!! Here’s a totally newbie trying to set up my new Orbi RBK 53. My house is totally wired with cat6 cable and I have ethernet access in every room provided via my ISP router connected to ...
Jun 13, 2020Guru - Experienced User
What mode is your ISP modem working in? router mode?If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What is the Mfr and model# of the ethernet switch in the configuration?
Yes you can connect the NAS to the RBR.
