Pseudocharro
Jun 12, 2020Tutor
Orbi RBK53 subnet
Hi everyone!! Here’s a totally newbie trying to set up my new Orbi RBK 53. My house is totally wired with cat6 cable and I have ethernet access in every room provided via my ISP router connected to ...
Jun 13, 2020Guru - Experienced User
What mode is your ISP modem working in? router mode?If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What is the Mfr and model# of the ethernet switch in the configuration?
Yes you can connect the NAS to the RBR.
Pseudocharro
Jun 13, 2020Tutor
Thanks!
To me, third option seems to be easier and the best.
Don’t know much about the switch, is a generic device installed by the telecommunications operator that did the installation.
By the way...RBR means rear LAN port?
- CrimpOnJun 13, 2020Guru - Experienced User
Pseudocharro wrote:
By the way...RBR means rear LAN port?"RBR" is the router. "RBS" is a satellite.
- PseudocharroJun 14, 2020TutorUps!! Got it!!😬
Thanks!
- FURRYe38Jun 14, 2020Guru - Experienced User
Yes, 3rd option will be good for you.
Hope it works well.
Pseudocharro wrote:
Thanks!
By the way...RBR means rear LAN port?- PseudocharroJun 14, 2020TutorThanks, Furry
:smileywink:
