Pseudocharro
Jun 12, 2020Tutor
Orbi RBK53 subnet
Hi everyone!! Here’s a totally newbie trying to set up my new Orbi RBK 53. My house is totally wired with cat6 cable and I have ethernet access in every room provided via my ISP router connected to ...
Jun 14, 2020Guru - Experienced User
Yes, 3rd option will be good for you.
Hope it works well.
Pseudocharro wrote:
Thanks!
To me, third option seems to be easier and the best.
Don’t know much about the switch, is a generic device installed by the telecommunications operator that did the installation.
By the way...RBR means rear LAN port?
Pseudocharro
Jun 14, 2020Tutor
Thanks, Furry
- FURRYe38Jun 14, 2020Guru - Experienced User
:smileywink:
