bigbruin
Jan 12, 2021Aspirant
Orbi RBK53 System Acting Odd Lately
I posted this yesterday, but it seems the thread was locked. If something is wrong with what I am posting, please let me know, as I really would like some help. I have an RBK53 system with the RB...
Jan 12, 2021Guru - Experienced User
Ok this is finally unlocked.
So if you turn OFF all but the RBR first and check the FW update page, what do you see? Then turn ON the RBS50s and check.
Would be a good test to disable Armor as well on the RBR, apply the setting, power OFF the RBR for 30 seconds then back ON and check the FW update page.
- bigbruinJan 13, 2021Aspirant
Thanks - I'll try these ideas later and see what happens.
- FURRYe38Jan 13, 2021Guru - Experienced User
You might factory reset and setup from scratch on everything as well if nothing seems to change.
- vajimJan 13, 2021Master
proceed with caution
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
