WhatsUpperDude
Mar 19, 2019Follower
Orbi RBK53 System Firmware Updates
I Just got the orbi system a couple monthes ago and its def. not up to date i have the V1.4.0.18 but when i check it says no new firmware but when i look anline it shows theres an update however d...
Mooose
Mar 19, 2019Luminary
I believe you can go straight to 2.2.1.212 and then upgrade to 2.3.0.32 from there. Try it.
