mf26uk
Oct 15, 2019Aspirant
Orbi RBK53 United Kingdom compatibility
Hi there. I live in the U.K. and considering buying the Orbi RBK53 from the US but wondering if the voltage of the unit for sale there is designed to be compatible only for the voltage/power supply in...
- Oct 15, 2019
Just to clarify, the US Orbi power adapter will work for all regions, including the UK. However, you'll need to get a separate wall plug or outlet adapter specific to UK.
Oct 16, 2019Guru - Experienced User
Pease post in the main Orbi forum next time for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Good Luck.
mf26uk wrote:
Hi there. I live in the U.K. and considering buying the Orbi RBK53 from the US but wondering if the voltage of the unit for sale there is designed to be compatible only for the voltage/power supply in the US. Also, are the supplied power cables/plugs only useable in the US? Thank you
- mf26ukOct 16, 2019Aspirantđ€
