Tariq_37
Jul 16, 2019Aspirant
ORBI RBK53 vs RBK53S
 Just asking about the differences between Orbi models RBK53 and RBK53S ? Is there any extra features in the second model ?
Jul 16, 2019Guru - Experienced User
Tariq_37
Also noticed usb flash port in the back of RBK53 which is not there in RBK53S model !! I am confused here !!
- schumakuJul 16, 2019Guru - Experienced User
Tariq_37 wrote:Also noticed usb flash port in the back of RBK53 which is not there in RBK53S model !! I am confused here !!
AFAIK the USB 2.0 port in place on the RBR50 and the RBS50 (making the RBK53 kit) has no function - no ReadyShare, no USB storage support, no USB network sharing, .... so it was pretty save to remove.
 - FURRYe38Jul 16, 2019Guru - Experienced User
Possible it was removed for v2 or just wasn't included in the pictures used the spec sheets. Would have to see a physical RBRv2 to see this...
- Tariq_37Jul 16, 2019AspirantThanks guys.. But also comparing both data sheets I noticed differences in the weight of each unit (RBK53 more heavy) and the flash memory. I am not sure about other features like Circle support as well. Also after searching, RBK53S is not available outside the US. Any other differences infos and features between both to share please !!
