indyjukebox
Mar 03, 2021Follower
Orbi RBK53 with Vodafone Modem and Firewall query?
A quick query. I have my Vodafone modem/router with wifi turned off and connected to the Orbi base unit. Everything works well. My question is regarding the Firewall status of the Vodafone modem. Sho...
Mar 03, 2021Guru - Experienced User
There is a built in firewall on RBR so having one in front of the RBR is redundent.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can try option #2 if your modem can't be fully bridged...
