wes1414's avatar
wes1414
Follower
Mar 14, 2019
Orbi RBK53
#1 The signal strength is strangly lower in some places than others around the base router. Just on the other side of my home office wall, the signal drops to 50%?  Does this have anything to do with channels or is there a way to optimize channels throughout the orbi network?  I can't find anything on the topic.
#2  Also if i can't get the signal up by optimizing channels, can i add a nighthawk router to the orbi so i don't have to buy another sattelite?  I have a centurylink modem/router.  I turned off the router part and installled orbi.   Orbi is then connected to my ethernet switch that runs throughout the home for security, cameras, tv's etc.  Can i add the nighthawk to an ethernet port elsewhere the signal sucks and configure it as an access point?
    That's Wi-Fi.  How are you measuring signal strength, for 2.4G and 5G?  How big is this house that an Orbi and two satellites do not provide adequate service?
    wes1414 wrote:
    #2 ...Can i add the nighthawk to an ethernet port elsewhere the signal sucks and configure it as an access point?
    Yes, of course you can add the Nighthawk as an Access Point.  (I have done so.)  HOWEVER, please understand that ONLY Orbi satellites create a "seamless mesh" Wi-Fi network.  Devices will not "hand off" between the Orbi and Nighthawk.  (It doesn't matter to me because I put the Nighthawk in to provide Wi-Fi to some IP cameras that do not move.  I even gave the Nighthawk a different SSID.)
  • What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
