Srmodi1963
Mar 25, 2019Tutor
ORBI RBK53
I have this orbi system and it was working fine until today in the morning. last night when I went to sleep every thing was ok and working. today In the morning no wifi net work name found. I turn on ...
- Mar 25, 2019
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Yes you can reset and setup from scratch using a wired PC and web browser.
Srmodi1963 wrote:
I have this orbi system and it was working fine until today in the morning. last night when I went to sleep every thing was ok and working. today In the morning no wifi net work name found. I turn on and off both router and modem but it does not work . what do you think. what should I do. reset every thing ?
Mar 25, 2019Guru - Experienced User
Srmodi1963
Mar 25, 2019Tutor
every thing working properly. just overnight something happened. may be FW update. i have auto update.
- Srmodi1963Mar 25, 2019Tutor
modam and router both net gear.
- FURRYe38Mar 25, 2019Guru - Experienced User
Ok. Post back if something else happens.
Please give feed back to questions if this continues. Details are important.
Enjoy. :smileywink:
