Cbard's avatar
Cbard
Follower
May 05, 2019
Orbi RBK53
I need to hardwire the two Satellites to the Orbi router. When I attached the satellitese with a lan cable the whole system locks up
  • Maybe things have changed recently, but before attaching LAN cable (wired backhaul), you have to setup backhaul via wireless first.  If you've already done that, please ignore this.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    Be sure Daisy chain is disabled on the RBR.
