NAL
Jan 17, 2020Follower
Orbi RBK53
Can I add another Orbi satellite to my recently installed RBK53? I want to purchase another Orbi satellite to go into my nearby annex which is 62 feet away from the new Orbi RKK53 router. Can anyone ...
- Jan 17, 2020
Been some users mentioning having 6 RBS connected all at once.
NAL wrote:Can I add another Orbi satellite to my recently installed RBK53? I want to purchase another Orbi satellite to go into my nearby annex which is 62 feet away from the new Orbi RKK53 router. Can anyone please recommend the Orbi satellite model I should buy RBK 50??
Thanks
Jan 17, 2020Guru - Experienced User
Any of the satellites will work.
the benefit to the RBS50 is that is has a wider (higher throughput) backhaul.
