beeatwork
Dec 19, 2019Aspirant
Orbi RBK53S - having problems connecting to the router via the computer
Can't login to the router from my computer comes back with an this error message, what does this mean, is there another way to gain access to the router functions? Thanks for the help in advance!! ...
beeatwork
Dec 20, 2019Aspirant
Thanks for the help! I ended up in resetting the router to factory settings. It was a lot of work, but it's back up and working!
Dec 21, 2019Guru - Experienced User
Glad you got it working. Be sure to do a backup configuration to file for safe keeping.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
