Redchotmelter
Oct 04, 2021Aspirant
Orbi RBK53s blocking IPTV app on firestick
Hi, I recently purchased the Orbi RBK53s to improve our Wifi and the results have been fantastic, but it's blocking my iptv app on my firestick - all was working fine before the Orbi was installed. ...
- Oct 05, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 04, 2021Guru - Experienced User
Does the firestick work if connected to the RBR and not the RBS?
- RedchotmelterOct 04, 2021Aspirant
Already tried, It didn't make any difference unfortunately
- CrimpOnOct 04, 2021Guru - Experienced User
Is the ipTV app the only app that fails on the Fire Stick?
Does this Orbi have Armor or Parental Controls enabled?
It's just the iptv, all the other stuff on the firestick, Amazon Prime, Youtube is all working - yes it has the Armor on, and it keeps on saying it's blocked something on the firestick, which I believe is probably the iptv, but every time i try and access security in the Orbi app, it crashes
