Redchotmelter
Oct 04, 2021Aspirant
Orbi RBK53s blocking IPTV app on firestick
Hi, I recently purchased the Orbi RBK53s to improve our Wifi and the results have been fantastic, but it's blocking my iptv app on my firestick - all was working fine before the Orbi was installed. ...
- Oct 05, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 04, 2021Guru - Experienced User
Does the firestick work if connected to the RBR and not the RBS?
Redchotmelter
Already tried, It didn't make any difference unfortunately
- CrimpOnOct 04, 2021Guru - Experienced User
Is the ipTV app the only app that fails on the Fire Stick?
Does this Orbi have Armor or Parental Controls enabled?
- RedchotmelterOct 04, 2021Aspirant
It's just the iptv, all the other stuff on the firestick, Amazon Prime, Youtube is all working - yes it has the Armor on, and it keeps on saying it's blocked something on the firestick, which I believe is probably the iptv, but every time i try and access security in the Orbi app, it crashes
- FURRYe38Oct 04, 2021Guru - Experienced User
Disable Armor by factory resetting the RBR and use a wired PC connected to the RBR and setup the RBR using a web browser.
When you get to the home screen and Armor appears, select Don't Show Again.
Test the IPTV and firestick again...
