SoyGreen
Oct 28, 2019Aspirant
Orbi RBK53s vs. Nighthawk x6s... Ethernet half the speed?
Soooo ok... I have Gig internet at home and had the Nighthark x6s setup. Had issues with the x6s... it loses its config anytime it loses power. Got PRETTY annoying, I upgraded - so I thought - to...
Oct 29, 2019Guru - Experienced User
What is the model# of the Hitron modem? There a built i router here by chance or is it just a modem?
FYI:
SoyGreen
Oct 29, 2019Aspirant
The Model name is CODA-47 and it should be a modem only. (My friends who have used their managed wifi services have a second box for that...)
And a factory reset after FW update? Do you mean that I should reset from scratch again after the FW update that was done during the initial setup I did?
- plemansOct 29, 2019Guru - Experienced User
I've read of some issues with the most recent firmware. You can always downgrade the firmware a version and see if that helps. Make sure to factory reset it if you downgrade.
Most people don't need to factory reset after an update. Whenever people are having issues though, its a good first step in troubleshooting.
- SoyGreenOct 29, 2019Aspirant
Got it - I will try that this evening after work... my boss won't accept "I needed more internets" as a reason to sign off early I imagine. :)
Thanks!
- FURRYe38Oct 29, 2019Guru - Experienced User
Please give a factory reset and setup from scratch a try.
SoyGreen wrote:The Model name is CODA-47 and it should be a modem only. (My friends who have used their managed wifi services have a second box for that...)
