SoyGreen
Oct 28, 2019Aspirant
Orbi RBK53s vs. Nighthawk x6s... Ethernet half the speed?
Soooo ok... I have Gig internet at home and had the Nighthark x6s setup. Had issues with the x6s... it loses its config anytime it loses power. Got PRETTY annoying, I upgraded - so I thought - to...
SoyGreen
Oct 29, 2019Aspirant
The Model name is CODA-47 and it should be a modem only. (My friends who have used their managed wifi services have a second box for that...)
And a factory reset after FW update? Do you mean that I should reset from scratch again after the FW update that was done during the initial setup I did?
Oct 29, 2019Guru - Experienced User
Please give a factory reset and setup from scratch a try.
SoyGreen wrote:The Model name is CODA-47 and it should be a modem only. (My friends who have used their managed wifi services have a second box for that...)
