NeoVN
Sep 12, 2019Aspirant
Orbi RBK53S Wifi Mesh and Lan Mesh problem.
I have some problems about setup my Orbi RBK53S network. I had 1 RBK53S (1 x RBR50 and 2 x RBS50) and I bought one more RBS50. So I had 1 x RBR50 and 3 x RBS50. My system running firmware v2.3.5.3...
NeoVN
Sep 13, 2019Aspirant
My router is Draytek.
Orbi system running as AP.
My switch and hub are gigabite.
Draytek connect to RBR50 and switch
RBR50 connect to RBS50 (satellite 1)
switch connect to RBS50 (satellite 2)
RBS50 (satellite 2) connect to RBS50 (satellite 3).
Sep 13, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- NeoVNSep 13, 2019AspirantWhat is MFR mean???
The Switch model Linksys LGS108.- CrimpOnSep 13, 2019Guru - Experienced User
Maybe "Manufacturer"?
- FURRYe38Sep 14, 2019Guru - Experienced User
MFr is Manufacturer.
Not fully sure if this model switch is managed or not. I don't believe so. Thought it has some features that maybe incompatible with Orbi:
- QoS
- Meets EEE (Energy Efficient Ethernet) 802.3az standard
I would remove this switch temporarily and test with RBS directly connected to the RBR to see if there are differences in behavior. Non manged and non Green Ethernet switches are preferred for use with Orbi if possible.
NeoVN wrote:
What is MFR mean???
The Switch model Linksys LGS108.- NeoVNSep 14, 2019AspirantI tested alot ways.
I think something going wrong in the firmware.
Because my network system is working good. I can connect wifi and Lan to internet with the best speed.
Hope the next firmware can slove my problem.
