Danatt's avatar
Danatt
Follower
Jul 07, 2021
Orbi RBK753 wired backhaul slow after power outage
After a power outage I had to re enter the internet setting in my RBR750 because (I don’t know how) the outage changed some values. After this the wired satellite (and the wireless one downstream) were working but at a fraction of the speed of tue router (600 vs 7 mbps download). I reset the whole system but I keep getting the same speeds.
Maybe it’s worth noting that after resetting the wired satellite and later the wireless one had difficulty syncing to the router and “out of sync” was displayed on the satellite status page, but after an hour the status changed to “good” and has been so since.
Any tip is appreciated
  • Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
1 Reply
  • FURRYe38's avatar
    Thank you.
