Takeda
May 15, 2021Aspirant
Orbi RBK843 satellite poor or out of sync backhaul status
I just installed a RBK843S Orbi system. Here is how it is intalled: Router | 1...
Takeda
An update, I just tried switching the satellites back to how they were originally, and now the backhaul status is "GOOD" on both satellites.
Go figure.......
- TakedaMay 15, 2021Aspirant
Yes, another update: I just noticed that after switching the satellites back, both satellites are connected directly to the router, instead of being daisy chained. When the backhaul status was bad, satellite #1 was connected to the router, satellite #2 was connected to satellite #1.
How can you control this?
- michaelkenwardMay 16, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you could get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.- TakedaMay 19, 2021Aspirant
Problem solved, I ordered another system from Costco, and returned this system for a refund. The newer system doesn't have any problems.
