Kinglg
Jul 17, 2020Aspirant
Orbi RBK852 compatible with A6100 WiFi adaptor?
My NETGEAR A6100 WiFi adaptor cannot found the WiFi signal from the Orbi wifi6. It can found my neighbour's though. I used to use it with nighthawk R7000 and worked well...anyone can help?
I tried to install the A6100 driver then the problem fixed.
Either post in the Orbi AX forum or the Wifi Adapter forum regading this.
Kinglg wrote:My NETGEAR A6100 WiFi adaptor cannot found the WiFi signal from the Orbi wifi6. It can found my neighbour's though. I used to use it with nighthawk R7000 and worked well...anyone can help?
- hrohmstillingsAspirant
I have the same issue and would like to know an answer.
