MarkSc
Feb 02, 2022Aspirant
Orbi RBKE960 constantly hitting custom NTP server
I have elected to use a preferred NTP server in my router settings rather than the Netgear default option. I am using this exact text "pool.ntp.org". I have a Raspberry Pi on my network that is telli...
- Feb 04, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
Feb 03, 2022Guru - Experienced User
And this happens with any custom time server?
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
MarkSc
Feb 03, 2022Aspirant
Thank you for your reply. Gave me some ideas to look into. Turns out it was my smart switch that was constantly hitting the time server. Interesting on how it said it was the IP of the router instead of the IP of the switch. Regardless, the issue is resolved. I turned off SNTP time sync on the switch.
- FURRYe38Feb 04, 2022Guru - Experienced User
Enjoy.
