DScone
Feb 14, 2018Star
Orbi RBR & RBS Ethernet Backhaul Help
I have Centurylink Fiber 1Gig up and 1 Gig down. In order to get rid of Centurylink's Modem/Router combo I had to utilize PPPOE and VLAN Tagging. I setup the VLAN Tagging on my TP Link Smart Switch (...
DScone
Feb 15, 2018Star
t_kwrote:
DSconewrote:Thank you for the detailed response. I really appreciate the help! Your explanation makes perfect sense.
Well... Looks like I won't be able to do this because my ONT is in the basement and is connected to my switch. I have one cat5 going upstairs in the family room (Orbi Router - Router Mode) and another cat 5 going in a upstairs bedroom (Orbi Satellite) on the oposite side of the house. I would need two cat5's in order to do what you described going up to the family room. I could bring the Orbi Router in the basement but I minimze the coverage in the family room.
My main purpose here was to use the TP Link switch to do the VLAN tagging and the Orbi to do the PPPOE login to avoid the Centurylink Modem/Router (c3000z). Guess I could hook this up as the router and put my Orbi's in AP Mode. Could you explain how to do this? Would I simply just hook up both the Orbi's up to the c3000z's ports and it would work? - Take the switch out all together.
Don't change AP vs routed mode over this! You don't need 2 cat 5 cable runs! Just because the Orbi's don't propertly support VLANs, doesn't mean you're out of the game. You just need two more steps.
Step 1: Put a managed switch upstairs near where your router is
This can be your basement switch, if it is small and quiet. If not, just buy a cheap 4 port managed switch (faneless, preferrably). They are about $65 if you get a new one.
Step 2: Setup the new switch like mentioned earlier
The modem gets plugged into the cable line that runs upstairs and goes into Port 1 on the switch. The rest remains the same as my note earlier.
The only down side is that you'll have to organize 4 cables so it looks nice. If you get a switch with flashing lights, maybe you'll have to carefully put electrical tape over the LEDs too. But, all in all, it'll be clean.
Now, say you really don't want to put a managed switch near the Orbi router. AP mode is possible with a single cable, but that means something else will need to provide routing/DCHP/NAT services. And, whatever it is, will need to be in your basement. If you don't want to use the CenturyLink modem's built in features, I would suggest getting a cheap pfSense box. For reference, that's what I use.
What happend to your post about trunking? It disappeared?
t_k
Feb 15, 2018Luminary
DScone It's back now. Looks like it was caught in a spam filter for some reason. A netgear moderator was able to recover it.
- DSconeFeb 16, 2018Star
t_k A update on last night. I was able to get your switch suggestion working properly. I did some test though... When setting the Orbi to do the PPPOE and the Switch to handle the VLAN tagging I notice the speed seems to be some what inconsistent. Before I set this all up I tested the Orbi to run in AP Mode just for the heck of it and used the Centurylink c3000z Modem/Router as the router (wireless turned off). I got much better and more consistant speeds (wireless and wired). I have read that PPPOE and VLAN tagging can somewhat cause some stress on the router and thus bottlenecking the speed.
I have also read about your pfsense idea and I actually would possibly prefer that... But until then I think I might just do the AP Mode with the centurylink router. I appreciate the time you are taking to help me out. Could you give me the best senario to do for AP Mode with Ethernet Backhaul?
- t_kFeb 17, 2018Luminary
DScone I'm glad you got the setup working, at least!
Regarding your inconsistent speeds on PPPoE, I can't be of too much help there because I haven't had to use that feature of the Orbi. But, it wouldn't surprise me at all if the Orbi's PPPoE implementation was poorly tested and poor performing.
I should try to steer you away from trying to troubleshoot VLANs as a source of the slow down though. VLANs and VLAN tagging is has near-0 overhead. In a small nome network, it would be astonishing if it was even detectable. 802.11q is designed to be super lightweight. I mainly bring this up so you don't try to chase that as a problem.
As for pfSense, it's great - though it may provide more features than you need. For us, we use the VPN client/server features, traffic shaping, and VLAN support of pfSense (in additional to the regular stuff). If you don't have any of those needs, it may be a little bit of overkill. Though, once you own a pfSense box, you probabaly won't go back :-).
Anyway, adding a pfSense box into the mix and putting it all together, here's what I would say your cleanest option is:
1. CenturyLink Modem -> WAN port of pfSense box (typically called em0)
2. LAN port of pfSense box (typically called em1) -> Basement switch, untagged for default VLAN
3. WAN port of Orbi router -> Basement switch, untagged for default VLAN (basically, the wall jack)
4. Any port of Orbi sattelite -> Basement switch, untagged for default VLAN (again, just the wall jac)
In this scenario you don't need VLANs setup on your switch in the basement and you don't need a second switch.
However, I really should bring up an important alternative. If you're going to go through the effort and cost of setting up a pfSense box and using a wired backhaul, then you'll probably be much happier with a Ubuqity Unifi setup. The Orbi's wired backhaul is so unreliable right now that it's maddening. Maybe they'll fix it later, but netgear fixed significant stability issues for over 8 months, so I wouldn't hold my breath. I would just see it being really frustarting to get the rest of your network setup and well designed only to still deal with unstable connectivity.
