DScone
Feb 14, 2018Star
Orbi RBR & RBS Ethernet Backhaul Help
I have Centurylink Fiber 1Gig up and 1 Gig down. In order to get rid of Centurylink's Modem/Router combo I had to utilize PPPOE and VLAN Tagging. I setup the VLAN Tagging on my TP Link Smart Switch (...
t_k
Feb 15, 2018Luminary
DScone It's back now. Looks like it was caught in a spam filter for some reason. A netgear moderator was able to recover it.
- DSconeFeb 16, 2018Star
t_k A update on last night. I was able to get your switch suggestion working properly. I did some test though... When setting the Orbi to do the PPPOE and the Switch to handle the VLAN tagging I notice the speed seems to be some what inconsistent. Before I set this all up I tested the Orbi to run in AP Mode just for the heck of it and used the Centurylink c3000z Modem/Router as the router (wireless turned off). I got much better and more consistant speeds (wireless and wired). I have read that PPPOE and VLAN tagging can somewhat cause some stress on the router and thus bottlenecking the speed.
I have also read about your pfsense idea and I actually would possibly prefer that... But until then I think I might just do the AP Mode with the centurylink router. I appreciate the time you are taking to help me out. Could you give me the best senario to do for AP Mode with Ethernet Backhaul?
- t_kFeb 17, 2018Luminary
DScone I'm glad you got the setup working, at least!
Regarding your inconsistent speeds on PPPoE, I can't be of too much help there because I haven't had to use that feature of the Orbi. But, it wouldn't surprise me at all if the Orbi's PPPoE implementation was poorly tested and poor performing.
I should try to steer you away from trying to troubleshoot VLANs as a source of the slow down though. VLANs and VLAN tagging is has near-0 overhead. In a small nome network, it would be astonishing if it was even detectable. 802.11q is designed to be super lightweight. I mainly bring this up so you don't try to chase that as a problem.
As for pfSense, it's great - though it may provide more features than you need. For us, we use the VPN client/server features, traffic shaping, and VLAN support of pfSense (in additional to the regular stuff). If you don't have any of those needs, it may be a little bit of overkill. Though, once you own a pfSense box, you probabaly won't go back :-).
Anyway, adding a pfSense box into the mix and putting it all together, here's what I would say your cleanest option is:
1. CenturyLink Modem -> WAN port of pfSense box (typically called em0)
2. LAN port of pfSense box (typically called em1) -> Basement switch, untagged for default VLAN
3. WAN port of Orbi router -> Basement switch, untagged for default VLAN (basically, the wall jack)
4. Any port of Orbi sattelite -> Basement switch, untagged for default VLAN (again, just the wall jac)
In this scenario you don't need VLANs setup on your switch in the basement and you don't need a second switch.
However, I really should bring up an important alternative. If you're going to go through the effort and cost of setting up a pfSense box and using a wired backhaul, then you'll probably be much happier with a Ubuqity Unifi setup. The Orbi's wired backhaul is so unreliable right now that it's maddening. Maybe they'll fix it later, but netgear fixed significant stability issues for over 8 months, so I wouldn't hold my breath. I would just see it being really frustarting to get the rest of your network setup and well designed only to still deal with unstable connectivity.
