thernelind
Sep 24, 2020Follower
Orbi rbr 20, firmware V2.5.1.16 , synology nas
When connecting My NAS to the ethernet port on the slave unit then DLNA can work for units connected (wifi) to the same orbi slave then it will work well but devices connected (wifi ) to router then...
Mikey94025
Sep 25, 2020Hero
thernelind wrote:When connecting My NAS to the ethernet port on the slave unit
then DLNA can work for units connected (wifi) to the same orbi slave then it will work well but devices connected (wifi ) to router then DLNA server is not found
anyone how know what i must do or if it will not work
// thomas
Is the NAS IP address pingable from wireless devices connected to the router? Is DNLA the only thing not working but otherwise the NAS is visible to all devices in your Orbi network?
Please describe how the satellite is networked to your base router, e.g., is it wired or wireless? If wired, are there any network switches between the satellite and router? If yes, what brand/type and are these switches "green" or managed (vs. unmanaged)? Some types of switches have disrupted connectivity between Orbi wireless devices.
