slimpdog's avatar
slimpdog
Orbi RBR 20 keeps dropping internet
Multiple times a day, my Orbi system drops internet connection. App shows Router as red and satellite as green. Status says offline with 1 satellite. Router shows purple ring. Please help!
1 Reply
  • FURRYe38's avatar
    Do both wired and wireless connections drop?
