LoboTommy
May 21, 2020Luminary
orbi rbr 20 wifi lost
this one is a puzzle to me. Network became tremendously unstable again. had to factory reset and set up from scratch. had a hard time getting the router back online, same with the satellites (rbs20-ie...
LoboTommy
May 22, 2020Luminary
it does not see it at all. no use trying to force the laptop to connect by setting up the network manually either. it does not support 5ghz to my knowledge.
LoboTommy
and firmware. I downgraded to previous version, as the newest gave orbi the hiccups again...
- LoboTommyMay 22, 2020Luminaryrouter status
- LoboTommyMay 22, 2020Luminaryivp6 disabled. sorry for many posts. but can only attach one image at time
- FURRYe38May 22, 2020Guru - Experienced User
What is the model# of the one that shall not be named and what what is the mfr and model# of the wifi adapter installed in this LT?
Seems like thre maybe a incompatibility issue with this adapter and the Orbi wifi.
If you updated to v16, did you perform a factory reset and setup from scratch prior to downgrading?
