LoboTommy
May 21, 2020Luminary
orbi rbr 20 wifi lost
this one is a puzzle to me. Network became tremendously unstable again. had to factory reset and set up from scratch. had a hard time getting the router back online, same with the satellites (rbs20-ie...
LoboTommy
May 22, 2020Luminary
ivp6 disabled. sorry for many posts. but can only attach one image at time
May 22, 2020Guru - Experienced User
What is the model# of the one that shall not be named and what what is the mfr and model# of the wifi adapter installed in this LT?
Seems like thre maybe a incompatibility issue with this adapter and the Orbi wifi.
If you updated to v16, did you perform a factory reset and setup from scratch prior to downgrading?
- LoboTommyMay 22, 2020LuminaryHP Pavilion g6... wait. WHAT?!?!?!
turned it on again,48 hours since last time it was on.... all of a sudden it's alive!
although slow, only 10% internetspeed,but alive
(dl/ul 46.86/45.77 - normal is 450/440 Mbps)- FURRYe38May 22, 2020Guru - Experienced User
This G6 LT, it a 1x00, 1200 or 2000 thru 2300 series? Seems to be a few G6 models....
If the adapter is only 2.4Ghz then those are speeds you'll probably see on 2.4Ghz.
What is the connection rate you seeing while the adpter is connected?
- LoboTommyJun 02, 2020Luminary
Thank you for all the help. It seems i have chrashed a little harder than i thought after all. It want just the laptop. It was after all the Orbis.
So i run this one once again in frustration:
1xOrbi RBR20
3xOrbi RBS20
I have facotyrreset all of them by holding in a PIN in the reset hole, bringin them all back to original "orbi" network. I rebootet my fiberoptic modem - bridgemode connected to port 3 (debugged that one with my ISP - not had a single packageloss on internet. Steady 500/500 over tha last 8 months.
Turned on only the RBR20 - set it up towards internet. Wifi kept going on and off continioulsy. Firmwareupdated it to latest firmware RBR20-V2.5.1.16.
Added one satelite (took 4 resets to get it online) updated it to RBS20-V2.5.1.16. Turned it off, turned on the next orbi rbs20 and so on.
Finnaly all 3 are online, and they are now postioned back in their respective locations around the house. Now network is on/off/on/off every two minutes. (Rings turn magenta - blue -magenta - blue on all RBS). When i put on ONLY the RBS (turn off the RBSs) the ring on the RBR turns magenta - turns off - magenta - off (in sync with wifi/no wifi)
My setup has worked like a charm over the last close to a year now, so it has nothing to do with the distance to the RBR / RBS units.
I am currently running a debugfile.
Current settings:
ROUTER INFORMATIONHardware Version RBR20 Firmware Version V2.5.1.16 GUI Language Version V1.0.0.375 Operation Mode Router LAN Port MAC Address CC:40:D0:35:7F:85 IP Address 192.168.1.1 DHCP Server On WIRELESS SETTINGS (GENERAL)Region Europe 2.4G Channel 9(P)+13(S) 2.4G Mode Up to 400 Mbps 5G Channel 36(P)+40+44+48 5G Mode Up to 866.7 Mbps
Advanced Wireless Settings (5GHz 802.11a/n/ac) Enable SSID Broadcast - YES Enable WMM (Wi-Fi multimedia) settings - YES CTS/RTS Threshold (1-2347) Preamble Mode Automatic Long Preamble Short Preamble Transmit Power Control 100% 75% 50% 25% Backhaul Topology Enable Daisy-Chain Topology - NO Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices - NO Enable MU-MIMO - NO Enable Fast Roaming - NO I am stuck - again - with this network, and really no longer know what to do with it.
Anyone got ideas this time?
