LoboTommy
May 21, 2020Luminary
orbi rbr 20 wifi lost
this one is a puzzle to me. Network became tremendously unstable again. had to factory reset and set up from scratch. had a hard time getting the router back online, same with the satellites (rbs20-ie...
Jun 03, 2020Guru - Experienced User
This G6 LT, is it a 1x00, 1200 or 2000 thru 2300 series? Seems to be a few G6 models....
Do other devices have same problems with wifi or no?
LoboTommy
Jun 03, 2020Luminary
ok, forget about the laptop. it's the whole orbisystem and wifi now. now everything falls on and off
- FURRYe38Jun 03, 2020Guru - Experienced User
Enable Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless SettingsTry disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).After you do a full reset on the RBS and RBR.
If any of this fails to resolve the problem, make contact with NG support and ask about an RMA if thats an option.
