LoboTommy
May 21, 2020Luminary
orbi rbr 20 wifi lost
this one is a puzzle to me. Network became tremendously unstable again. had to factory reset and set up from scratch. had a hard time getting the router back online, same with the satellites (rbs20-ie...
LoboTommy
Jun 03, 2020Luminary
ok, forget about the laptop. it's the whole orbisystem and wifi now. now everything falls on and off
Jun 03, 2020Guru - Experienced User
Enable Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
After you do a full reset on the RBS and RBR.
If any of this fails to resolve the problem, make contact with NG support and ask about an RMA if thats an option.
