Bravo2
Oct 04, 2020Aspirant
Orbi RBR 20
I had functioning Orbi, worked great, then I got the idea to get another Orbi for a remote cabana which has Ethernet port wired directly with the internet service provider, I could use the Orbi as a...
Oct 04, 2020Guru - Experienced User
Did you get a RBR or a RBS?
What model Orbis do you have? RBR or RBS?
Is the RBR or RBS directly wired to the RBR or is there a ethernet switch in between?
Bravo2
Oct 05, 2020Aspirant
I have three RBR 20, all of show up on mobile devices, but will none will connect to the internet, they also will not pass through the wired connection at the outlet Ethernet port.
- MstrbigOct 05, 2020Master
Bravo2 wrote:I have three RBR 20, all of show up on mobile devices, but will none will connect to the internet, they also will not pass through the wired connection at the outlet Ethernet port.
read my post again, You have to trace that wired connection to see how it is connected.
- Bravo2Oct 05, 2020Aspirant
I tried three wired ports, all wired directly to Spectrums modem, no breaks, no switches, plus the fact that on Orbi has been working for a couple of years. It is only when I brought the used Orbi into the house did the older stop working and the new one too for that matter.
Bravo2 wrote:I tried three wired ports, all wired directly to Spectrums modem, no breaks, no switches, plus the fact that on Orbi has been working for a couple of years. It is only when I brought the used Orbi into the house did the older stop working and the new one too for that matter.
Why are the cables connected to the Spectrum modem? They should be connected to the Orbi router for wired satellites to work. Wiring can be Orbi router to switch to Orbi satellites, but not Spectrum modem to Orbi satellite.
