Bravo2
Oct 04, 2020Aspirant
Orbi RBR 20
I had functioning Orbi, worked great, then I got the idea to get another Orbi for a remote cabana which has Ethernet port wired directly with the internet service provider, I could use the Orbi as a...
Oct 04, 2020Guru - Experienced User
Did you get a RBR or a RBS?
What model Orbis do you have? RBR or RBS?
Is the RBR or RBS directly wired to the RBR or is there a ethernet switch in between?
Bravo2
Oct 05, 2020Aspirant
It is also interesting to note, that the one Orbi was working until i bought a "used" one on EBay.
then i bought a new on a few days ago from Amazon and it does work either. Could the "used" on have contaminated the other two?
