RajSearing
Dec 10, 2020Aspirant
Orbi RBR 40 causing 404 errors
Really RBR40 router but that wasn’t on list. Last week out of nowhere I started getting 404 Wanlan errors when trying to get on several websites. Online advice said to switch to AP mode by going to O...
Dec 10, 2020Guru - Experienced User
what modem/gateway do you have?
What ip address is the orbi using? You can use that to log into it.
Easy way to check is disconnect the orbi from the gateway, reboot the orbi and reboot the device connecting to it. Then when both reboot, pull up a command prompt and type ipconfig that should be the ip address of the orbi that you can log into
RajSearing
Dec 14, 2020Aspirant
I got the up address from my IMac Network settings. If I type into Google browser I get nothing. If I type into safari I get 400 bad request. If I type on command prompt I get command prompt not found
- RajSearingDec 14, 2020AspirantAlso. When trying to connect to Orbi. I type in www.orbilogin.net. And the freaking thing BLOCKS that page too. 404 wanlan error and asks for username and password
- plemansDec 14, 2020Guru - Experienced User
What modem/gateway do you have?
Try factory resetting the router to log back in. disconnect it from your modem during setup
