BrBranscum43
Jul 20, 2019Aspirant
Orbi RBR 40, Issues with new internet
So I recently moved to a new house. I tried hooking my Orbi Router and Satilite to the new internet. It seemed to work as I was able to load normal sites that I had been on before. I tried to connect...
- Jul 20, 2019
So I was able to fix it actually. It was that the Orbi was connected to a gateway and needed to be assigined another IP address.
CrimpOn
Jul 20, 2019Guru - Experienced User
We can offer possible solutions if you can provide a little information:
- What internet service company?
- What equipment is the Orbi connected to? (exact brand and model number)
- When you look at the Orbi "internet port", what IP address has the Orbi received from the service company?
Thanks
- BrBranscum43Jul 20, 2019Aspirant
- CrimpOnJul 20, 2019Guru - Experienced User
Thanks for reporting success. If you mark the topic solved it will show users it is no longer active.
