BrBranscum43
Jul 20, 2019Aspirant
Orbi RBR 40, Issues with new internet
So I recently moved to a new house. I tried hooking my Orbi Router and Satilite to the new internet. It seemed to work as I was able to load normal sites that I had been on before. I tried to connect...
- Jul 20, 2019
So I was able to fix it actually. It was that the Orbi was connected to a gateway and needed to be assigined another IP address.
BrBranscum43
CrimpOn
Jul 20, 2019Guru - Experienced User
Thanks for reporting success. If you mark the topic solved it will show users it is no longer active.
