kroth
Mar 02, 2020Aspirant
Orbi RBR 40 will not reset, blinks white ring
Orbi stopped working and flashes white ring, green LED stays lit on back. Try to reset, but nothing happens. Unit is about 2 years old and can not find any troubleshooting help for it. Is it dead?
Retired_Member
Mar 03, 2020
kroth wrote:Orbi stopped working and flashes white ring, green LED stays lit on back. Try to reset, but nothing happens. Unit is about 2 years old and can not find any troubleshooting help for it. Is it dead?
So your whole network is down? No wifi or Internet?
- krothMar 07, 2020Aspirant
No, I have my network up with my ATT Uverse. The Orbi just stopped working. The main router and satellite both down. Cannot reset. get different results with trying to factory reset with evertything I have found online. Do not see my wireless SSID when tring to reset to factory. Cannot connect with ethernet to admin anything.
- FURRYe38Mar 07, 2020Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
kroth wrote:No, I have my network up with my ATT Uverse. The Orbi just stopped working. The main router and satellite both down. Cannot reset. get different results with trying to factory reset with evertything I have found online. Do not see my wireless SSID when tring to reset to factory. Cannot connect with ethernet to admin anything.
