BCDozier
Dec 17, 2019Aspirant
Orbi RBR 40
How to connect ports 40000,41000,42000,43000 and 44000 to IP 64.90.194.232
CrimpOn
Dec 19, 2019Guru - Experienced User
It might help to provide more information about the request. IP 64.90.194.232 appears to be part of a group assigned to ViaWest in Charlotte, N.C. Perhaps this is the "public address" of your Orbi system?
If you want to open ports on the Orbi and have them connect to a specific computer within your LAN, that is done on the Orbi web interface, Advanced Tab, Advanced Setup, Port Forwarding. Instructions are in the Help information at the bottom of the web page. You have to specify which IP address on the LAN side of the Orbi these connections will go to.
Or, is do you want something different?
- BCDozierDec 20, 2019Aspirant
Attached are part of the instructions:
