smdunn
Apr 20, 2019Follower
Orbi RBR 50 - 404 Error when navigating from a link in email
Getting great wifi coverage with my New Orbi system and speed is good too, but hyperlinks embeded in email (both Apple and Google) trigger a 404 Not Found message when clicked ever since we switched on the network. Must be some weird security setting? Help! and Thanks! - Steve
I put the Orbi in AP mode and that seemed to fix the problem.
Did nothing else. Radios on the ATT 5268AC are still active.
Thanx for the fix.
- LadySAspirant
Did you find a solution to this problem? I am experiencing the same issue.
- FredfxAspirant
I’m having the same problem. I kept my other WiFi network up while we test the Orbi and only the Orbi network has the problem. It’s mostly when clicking links in e-mails. When the browser window comes up it’s usually a 404 error. I also noticed that many pictures in e-mails don’t download. Like I said. I have the previous network running redundantly and the problem doesn’t exist there.
‘’Could it be a security setting in the Orbi? It’s a bummer because the coverage is insanely great!
Any ideas? Netgear?
Is the Orbi system operating in Router or AP mode?
Fredfx wrote:I’m having the same problem. I kept my other WiFi network up while we test the Orbi and only the Orbi network has the problem. It’s mostly when clicking links in e-mails. When the browser window comes up it’s usually a 404 error. I also noticed that many pictures in e-mails don’t download. Like I said. I have the previous network running redundantly and the problem doesn’t exist there.
Any ideas? Netgear?
- FredfxAspirant
Hi Group:
Here is the requested info:
Orbi Model RBR50Firmware V2.3.1.60
Modem is ATT 5268AC (It's branded ATT but could it be PACE?)
I don't know how to tell what mode the Orbi is in whether it is Router or AP
I suspect it's in Router Mode.
