LeifA
Apr 20, 2021Apprentice
Orbi RBR 50 - no download speed
Hi! When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0). Everything else seems to work as before and othe...
- Apr 20, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LeifA wrote:Hi!
Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
Any suggestions why?
Regards
Leif
vajim
Apr 20, 2021Master
Tell us about this 4G modem/router
you do realize that you can't run 2 routers without special configuration?
