LeifA
Apr 20, 2021Apprentice
Orbi RBR 50 - no download speed
Hi! When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0). Everything else seems to work as before and othe...
- Apr 20, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LeifA wrote:Hi!
Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
Any suggestions why?
Regards
Leif
Apr 20, 2021Guru - Experienced User
Couple of options,
LeifA wrote:Hi!
Regards
Leif
- LeifAApr 20, 2021Apprentice
Thanks everyone for the different suggestions!
I have tried to disable all wifi radios on the modem and configured AP mode on the Orbi router.
It seems to work fine now.
Regards
Leif
- FURRYe38Apr 20, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
LeifA wrote:Thanks everyone for the different suggestions!
Regards
Leif
- FURRYe38May 15, 2021Guru - Experienced User
Sounds like something isn't configured right. I'd ask the ISP to help you ensure the modem is setup right, wfi radios are disabled and the Orbi is setup for AP mode.
Regards
Leif
- LeifAMay 15, 2021Apprentice
Should the Orbi be in AP mode if it is used as the only router after the modem?
Leif
Sadly, the same problem is back.
Orbi in AP mode, router wifi off.
Putting Orbi on router bridge port results in no internet on Orbi.
Leif
I'd contact your ISP and have them help you ensure there modem is configured correctly and is working. If the RBR is in AP mode, it should get internet services from the ISP modem/router if using a good quality LAN cable.
Now I have removed the other router and is running my Orbi RBR 50 directly on the 4G modem, but the problem still persists.
The upload test in the Orbo app works fine but no download test is performed, it shows 0.00 on both my iPhone and iPad.
No problem with other speedtest.
Regards
Leif
