LeifA's avatar
LeifA
Apprentice
Apr 20, 2021
Orbi RBR 50 - no download speed
Hi! When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0). Everything else seems to work as before and othe...
  • FURRYe38's avatar
    Apr 20, 2021
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    LeifA wrote:
    Hi!
    Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
    Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
    Any suggestions why?
    Regards
    Leif
